Coolant "drain and fill" vs. "flush"
Raven, good find. About a year and a half ago, when I was researching coolants due to the discovery of the gray sludge in my radiator, I came across other material published by the same author. One of the few articles I have read that provides a summary of the various coolant packages.
Following is an excerpt from the current article, that makes for some interesting reading:
"Original equipment coolants are validated for factory replacement parts. One of the issues that may arise is the use of an aftermarket replacement radiator or heater core made of copper-brass with lead solder. We have in previous articles pointed out that today's coolant inhibitor packages contain a small amount of copper-brass protection, but may provide little protection if a radiator is made with high-lead solder. Results of industry standard tests of the new Toyota extended-life coolant now show a substantial weight loss (corrosion), both in a 50-50 mix and in a 33% coolant mixture (solder corrosion is much greater in this more diluted solution).
If you have to change a radiator or heater core, use aluminum. Or, if it's an older car and the owner wants the lowest-cost radiator, you might procure a soldered-together copper-brass unit. Conventional American coolant should provide better protection against solder corrosion, which can result in radiator tube restrictions and leaks. But no coolant provides perfect protection.
If you're replacing aluminum parts on an engine, such as a water pump or even a new cylinder head, remember that part's coolant passages have not been protected. In those cases you should perform a complete coolant exchange." - Motor Magazine, P.W.
I wonder if that applies to the early brass 3 row also? Is it soldered or brazed?
