Coolant Concentration?
State of Flux...
I'm about to tackle the PHH, t-stat, blue-hub fan clutch and will change the fuel filter and rebuild my starter while 'in there'. Does anyone have any recommendations for the most effective coolant mixture for hot climates like here in Dallas, TX? I want to do this only once every 3 or so years. I'll be using Toyota Red and distilled water. Should I just mix it 50/50 OR 30/70...or other? Lastly, I'm thinking about dumping in a bottle of Red Line Water Wetter on top of everything. Any / all info. is appreciated. :beer:
BTT...
I'd be interested in this too, the FSM doesn't speak of the proper mixture. I've got my Toyota factory Red I just bought, and am planning on doing it next week. FSM does say to use distilled but doesn't give a suggestion for mixture.
The coolant bottle should say right on the label what concentration will protect down to what temp. Pick the temp you'd like to be protected to and use that ratio. Be sure you're using the undiluted Red, as it's now sold in a premix as well. Also, having a third container on hand to premix before pouring it in is a good idea as sometimes you won't get in as much as you think and if you poured all the coolant in first (or vice versa) you'll be way off the mix when suddenly it's full. For 50/50 I pour half a coolant container in, then half a gallon of water. Then fill the half empty coolant container with water and pour that in. Then I've got a 50/50 mix no matter what. This assumes you were smart and drained/flushed properly with the block drain and heater valve to full (with key on so it moves the electric valve), etc.
DougM
50/50 usually gives you the best cooling and freez protection.
Plain water gives better cooling than antifreeze mix. I start with 70% water, allowing for a few water top offs, if needed, without going under 80/20% mix for good corrosion protection.
Thanks for the advice...I think I'll be alright if I just fully drain the system and add only 1 gal of Toyota RED and the rest distilled water...Oh, and (1) bottle of Red Line Water Wetter. It's HOT here in June, July, Aug & Sept and it rarely gets below 25 deg. in the winter.
TX,
So you've gone from mixing it to a decision to just dump in a bottle of coolant, then see how much water goes in? OK.
DougM
If the capacity is 15.5 qts (3.875 gal)...then I'm assuming I'll reach an approx. 75/25 ratio by using only (1) gal. of coolant and the rest distilled water. Is this not okay for warm climates?
