Coolant concentration
LUGOFF, SC
So after following all the threads that said Toyota Red is going away, and to use the Prestone Toyota version,I refilled with this stuff two weeks ago:
My Prestone boil/freeze gage tells me its good from 256F down to 0DegF. That's fine here in SC, but I'm going to Old Forge in Upstate NY for Christmas, -20F or colder is the norm for overnight.
How do I get the concentration level up? Obviously I need to drain off a gallon of what's in there, and add a gallon of concentrate, but I can't find the Prestone Concentrate.
Can I mix Toyota Red with this? That I can get. Figures.
Does this stuff not work as well as the good ol' green? A 50/50 mix of green should be good down to -34 F (-37 C). At least that's what the charts I googled showed.
Did you pull the block drain when you flushed? Not doing that combined with what water remains in the heaters could be your issue. That is why I always use concentrate instead of the premix 50/50.
Yeah, well... I forgot the block drain which is about a 1/2 gallon of water. :oops: I haven't worried about block drains since living in VA and further points South. It wasn't a big deal till the fam decided to do Christmas in the Great Frozen North this year.
Normally the fam does Christmas in Western NY, which doesn't get that cold until mid Jan, early Feb.
I wouldn't have even checked it except Old Forge has day time highs of -10 that time of year.
:censor: me, I'm gonna freeze my a$$ off.
TOYOTA Full Strength RED is NOT going away
that's a FALSE Rumor
Try another tester. If it reads the same, empty the expansion tank and fill it with regular Prestone concentrate. The “formulated for Toyota” is BS.
