cool animation of engine assembly
Wow; that was fun!!
I had a blast trying to identify and say each part as it went on, but what was the short chain off the crankshaft for? Does it drive the oil pump?
Thanks Raven! :)
Curtis
The only thing that would make that cooler would be a narration so those mechanically challanged (like me) would no what every single part does. :o
sweet vid, i could use some subtitles showing what some of the parts are that are being put together.
Wow; that was fun!!
same here :)
Thanks Raven! :)
Curtis
I think so, there is a casting bulge in the block, I assume that has a drillin ginside that heads back to the oil filter boss that is shown later on, on the 1fz the oil pump is in the same spot but is gear driven instead of chain. also the PS pump is in the same area and also gear driven on the 1FZ.
another notable difference is the 1FZ the exhaust cam is not driven by the timing chain but instead gear driven from the intake cam (see my avatar) but the chain slipper setup is very similar.
I had a blast trying to identify and say each part as it went on...
I did the same thing.. Thanks for the video RT!
my old boss toured a deutz factory in Germany in the eighties sometime, he still could not get over how cool it was.
they were (are?) like VW used to be...own and make everything that goes into the tractor.
That's not really a tractor engine, is it?
I don't know what that motor goes in, I was thinking forklift but was just a guess, but it is similar to a 1FZ in construction and the LC motors are always called "tractor engines". maybe that saying has a seed of truth.
So post up! :)
No reason this couldn't be a tutorial. (Please note that I'm NOT claiming expertise here...)
Can you recognize the "big boys" like the block, head, crankshaft, pistons with their connecting rods, camshafts ("dual overhead" in this case), timing chain,...?
Cheers,
Curtis
I had this as a screen saver about a year ago.
tractors are high tech s***t these days, full of too much electronics and decent "highway worthy" engines
I'm just thinkin' tractor engines don't rev high enough to need 4 valves per cylinder but I may be off-base. I always thought they were short-stroke large bore high torque @ low RPMs vs. something tuned for vehicles.
For a hydrostatic style tractor thats all the engine does is spin a hydraulic pump,they are getting common and have a few very useful qualities as far as tractors go.
