Control arm bracket alternative
Fort Collins, colorado
I've searched a bunch and can't figure out what needs to be changed. I have the Man A Fre control arms and can not get the slee step sliders on with the arms. momma says we need full steps for kids.
What do I need in order to change it over so the regular sliders will fit?
Thanks
Would I remove the arms and use slee castor plate?
Yes, remove the brackets, then use either plates or bushings to address the castor depending on the amount you have after the brackets are removed...
Or just bring whatever sliders you choose to a fab shop and have them make them work. It would probably be easier and cheaper than removing your MAF brackets and installing caster correction bushings.
Do you have the sliders if so then snap a picture & post it up. Just recently a gentlemen had the same issue. He just flipped down the bracket mounted the slider than sandwiched the slider bracket between the frame & bracket.
