Considering 1" Spring Spacers
San Diego
I would like to add some 1" spacers to all 4 corners but I know this will lead to a bunch of other items I need to replace. I am going to list what I think needs to be done as I install the spacers and what needs to be done after I install the spacers. This will essentially take me from 2.5" to 3.5" of lift.
With the spacer install:
1. Extend the brake lines!
2. Swaybar brackets & 2" Bumpstop spacers!
After the install (as $$$ allows):
1. Additional castor correction? (remove blue CC bushings & replace with plates?)
2. Long Shocks?
If there are different or better recommendations, I would like to hear them......keep in mind that I'm on a tight budget.
Thanks!
2. Long Shocks?
Thanks!
You may or may not need to do all that.
  1. This will depend mostly on how much down travel you have. If you have OME-L's, then even on a 2.5" lift you will want to extend the brake lines. If you have stock shocks or the OME standard (shorter) shocks, then you may not need to. You can simply flex the truck and see how tight it gets. All that said, it's not a bad idea to do anyway. Don't forget about the ABS lines and emergency brake cable.
  2. Again, may or may not be necessary. I have about 3.5" of lift and have not done either. I may have to add sway bar drops now that I have longer shocks, but with the OME medium lift and standard shocks it was not needed.
    The bump stop spacers are only needed if you are going to be rubbing hard at full stuff or overcompressing your shocks. It's been my experience that the OME shocks (both standard and longs) have plenty of compression so bump stops are not needed unless you go with different shocks or are running large tires (37+). Again, flexing the truck and seeing what happens is an excellent way to see if it's needed or not.
  1. Measure your caster (after the lift) and decide from there. Personally, anything above 0* drives just fine in my book. I dislike the way my truck handles currently at about -1.6*, which is what it dropped to after adding the spacers. So it will all come down to how far off you are and what you are comfortable with.
  2. I'm a big fan of longer shocks. The OME standards are far too short IMHO. The Longs are a decent bolt in shock, hard to find something else that bolts straight in for that price and that length/range, which is just about perfect for our trucks. The Bilsteins are very very nice, but $$$. You can find Pro Comp's that will bolt straight in that are a bit shorter than the OME-L's, but also much cheaper. With some minor fab work you can easily put in 14" travel shocks in the rear (and switch to an eye/eye configuration). You can find a write-up on the Pro Comp's via the link in my sig.
My 80 had 3.5" with blue bushings and need no DC shaft. Drove fine.
My LX has 3.5" J springs with caster plates and had to get a ft DC shaft.
I made my own brake line drop brackets for the 80 with 6" and the LX with 3.5".
Longer shocks are always recommended if you are wheeling and the rear bumpstop lowering brackets can be made from 2" square stock.
I would like to add some 1" spacers to all 4 corners but I know this will lead to a bunch of other items I need to replace. ...
This is related to suspension travel, with the same shock travel, brake line length requirement doesn't change.
2. Swaybar brackets
Mostly related to caster correction, clearance needs to be checked at full suspension droop. May or may not be needed.
Mostly related to tire size and allowed suspension droop. Wouldn't be needed from just installing spring spacers.
May or may not be needed, depending on your preference, how it drives with your setup, tires, etc.
2. Long Shocks?
I prefer lots of flex travel, but needs the most tuning to achieve.
I have FOR 3.5" lift and I made my own brake line drop brakets at certain points and messed with the brake lines. I did not add any brake lines.
I have no castor correction yet but my rig handles fine with no vibes and such.
I converted all shocks to eye to eye with 10" up front and 12" in the rear with my own custom top shock mount bracket in the rear.
I did not extend sways or bump stops either.
In the rear I just put bump stops directly on the shocks.
I will be getting adjustable panhards because I want the truck centered.
Thanks for the replies so far, they have been helpful. So I will probably just start out with just the spacers and check everything for clearance when flexed. When I purchase longer travel shocks, I will address the brake lines and other things.
bpassmore, I found the spacers on the MAF website below:
MAF 80 Series 25mm Trim Packer
