Confer Aux Tank Schematic
I have the above installed in my 77 and I can not switch tanks. Just runs off the main tank. Appears to be either a bad fuel tank selector switch or tank selector module or whatever it's called is bad.
Thanks - Chris
Probably plumbed the smog legal way were all aux. tank gas gets suctioned up into the front main tank when you switch tanks from front to rear???. This is usually poo-poo, and you never know how much gas you actually do have. If you followed my Downey Fuel Cell instructions, you could plumb to use one tank or the other, in any order, both with their own sending units, a double pull/double throw switch that switches tanks AND sending units at the same time, and the instructions do have the wiring diagrams.
