Condensation in dizzy
890man
Thousand Oaks, Ca.
How do you guys keep the dizzy dry. I just go through a puddle a little fast and have problems. It also happens after driving in the rain. I shut down the motor to gas up or go in the store, get back in, fire it up and it runs rough. I pull the cap and there is moisture on the top of the cap shorting everything out. I never had this problem on my 78. This is a 12/74 with a stock setup.
Breather tube??? I dont have one of those. Only line is for the vacumn advance. If I silicone seal and no breather will that be a problem?
If you silicon the cap on it will be difficult to remove. And since there are vent holes in the distributor body it won't make much difference.
Silicon the vent holes closed. Use silicon grease (not sealant) between the cap and the body of the dist. Drill a couple of holes in the cap and install a draw through vent setup (like the '78 and later units have from the factory).
Mark...
Thanks Mark, I'll use the grease. As far as the vents go, are these in the cap? I went to sor to look at the diagrams and it looks like two vents come out the top and connect to something called a VCV. How does this system work? Do I modify a cap by drilling and tapping for a fitting or will the later model cap fit?
The one you are looking for is the line that goes to #70 in the drawing, which mounts on the firewall inside the cab. It allows for breathing but not H2O!. Not sure a 78' cap would fit on a 74' though....
Cheers!
I'll go with that, just a simple line and a filter mounted inside the cab. I do still want to see if later caps fit but I wont hold my breath. Where are the other vent holes located in the dizzy. I think I want to plug those up after I install the other vent to prevent any water a way to get in.
Thanks
That would be great but I dont think it would solve my problem. The water (condensation) is on the top of the cap shorting out the rotor and contacts, not the points. I like the thought though. I put it on my list.
The trick to using silicon seal to make a REMOVABLE seal is to clean both surfaces with degreaser. Then, on the surface that you do NOT want the silicon seal to stick to, which I would assume is the distributer itself, put a thin coating of motor oil on it with your finger or a small artists paintbrush. (Q-Tips can leave fuzz.) Put silicon on the distributer cap, then install the cap on the distributer. Let the silicon dry. If you put enough oil on all points of contact, the cap should lift off fairly easily without tearing the silicon, which has now formed a gasket. You can clean up the oil with a gentle degreaser, like alcohol. I've used this method for distributer caps, valve covers, etc. (The valve covers had the gaskets sealed in place, then a heavy bead of sealant was run over the exposed gasket, while the head surface was generously oiled to prevent sticking. Raced those same gaskets for years, despite frequent valve adjustments.)
The later model distributors ('78 and later) have a screw-down cap with an o-ring seal and molded fittings for the hoses that remove condensation. I think this is what projektdotnet was getting at in his suggestion. They have the added bonus of being fully electronic.
