In my 2013 LC world, the stock wheels have an offeset of 60mm and the TRD "Rock Warrior" wheels have an offset of 50mm.
The TRD wheels stick out 10mm more than the stock wheels.
Any aftermarket wheel with a lower offset value will stick out more than the stock wheels. E.g., a wheel with an offset of 30mm will stick out 30mm more than a stock wheel; and an aftermarket wheel with an offset of 20mm will stick out 40mm more than stock.
Here's a good tool for you to get an idea of how wheel offset will affect various wheel/tire characteristics:
Rim & Tire Size Calculator. Custom Offsets
Have fun with your wheel search. Also, bear in mind that the Load Rating for any wheel you are considering should be
>2500 pounds to match the safety of the OEM wheels. Further, be sure the center bore is 110 or 110.5mm so it will conform to the stock requirement of being hubcentric.
HTH
