Con-rod bolt substitute
Firstly I officially appologize PROFUSELY for asking this question:doh:! I was messing about in the bottom end of my motor today and wanted to check the condition of my rod and main bearings when i went to crack the nuts off the first rod cap, the first bolt promptly snapped, then the other one. Soooo, me thinks someone torqued these a little on the tight side last time, huh? Problem is that for the moment there is not an original rod bolt to be had here where I am so for an emergency would it be a really really bad idea to sub a regular grade 8 bolt if the head was machined to fit like an original rod bolt? How long might bolts like this last with mild use, no drag racing. If every I deserved to be flamed, now is the time... but better to just say yea or nay ;), oh and specify if its a STRONG nay or just a ¨better not¨nay....:wrench::wrench::wrench:
tanks yall
Mark...
After reading your other threads, I'd "chunk that junk" and go for a 2F or one of the other popular transplants......
i would consider a cap screw if your acually gonna do that they are about the strongest bolt out there.mostly used by machinests and you probably wouldnt have to machine any thing to fit them .i have never done this its just an idea that may or may not work good luck
Cap screw
Hey thats a good idea, appreciate it. Fwiw, what I want to do is get hold of one of those original mercedes desiels that are around down here and swap this boat anchor for that.
Mark...
there was a guy here buying parts once and said he was doing that but i never heard from him again so i dont know how that went agian good luck
You have got to be kidding... right?.. then again, probably not....
Well chaps, on the subject of the rod bolts, I found that the diameter of the original bolt shoulder is exactly 10mm, but the shoulder on the closest 10mm new bolt match had a shoulder of quite a bit less than a true 10mm. I found some 12mm cap screws that are labled 12.9 which as I understand it are a couple of steps above grade 8, and I´m having them machined to a perfect replica of the original rod bolts, cost... about 75$ total and yes... I think they will work just fine.
Boy they really tried to screw up this motor, it´s a fresh rebuild actually with really low miles, 30 over crank and 30 over rebore, new pistons. But... get this, the rod caps were SHIMMED with copper or brass leaves between the rod body and cap, which when removed gave pretty reasonable clearance of .0025. With the shims it was like .004, why on earth they did that is beyond me, how could they be so stupid? Even more incredible, with this new crank grind and 30 over bearings, they had MORE SHIMS on the main caps, giving a main bearing clearance of about .010??? Even with the shims taken out the clearance was like at least .008 on the mains. Its no wonder why my oil pressure was crap! Soooo, I am having the crank ground again for it´s last time at 40 over, have new bearings comming Saturday by Peru´s fastest donkey, fresh rings just to be kind, new oil pump, new valve job and head resurface, timing gears are perfect, cam lobes and lifters are nice looking, valve train parts are in good shape. It should run whadya think.
While I´m here I would like to ask if anyone could tell me where I can find the specs, tolerances and torque specs for this motor online?
Thanks for all the hep and still would appreciate any savy tips that don´t involve blueprinting the stupid engine.
Thanks guys.:cheers:
Hmmm, I cant imagine why they would be neccesary if things were done even remotely correctly, never ever seen them before and have worked on some old motors...? Still looking for specs, hint hint.
You need to have a machine shop re-size the rod bores back to spec. that will eliminate those needed home-brew added shims ...Specter has shim kits for the mains-- Specter Off-Road-Land Cruiser Parts - Search On-034-09 -- you better be careful on what you do in that area..... the rod bolt shoulders are design as such to act as dowels to help keep the cap & rod in alignment and tight.... so what about the heads of the bolts? did they machine them to fit?... whats the plan on nuts??... any balance concerns here??.... Personally I'd install 2F rods and be done with that part of it.........:beer:
Shims on the main caps are very important. Ask me how I know. My understanding of it is that those caps were cast on the block, and then later cut off the block. This process removes material, thus making the hole not round after bolting the cap back on. The shims are needed to true the hole and set the proper clearance. If you run them too tight, even on the tight side of specs you could potentially ruin the bearings.
Wierd japanese motor
QUOTE: You need to have a machine shop re-size the rod bores back to spec. that will eliminate those needed home-brew added shims ...Specter has shim kits for the mains-- Specter Off-Road-Land Cruiser Parts - Search On-034-09 -- you better be careful on what you do in that area..... the rod bolt shoulders are design as such to act as dowels to help keep the cap & rod in alignment and tight.... so what about the heads of the bolts? did they machine them to fit?... whats the plan on nuts??... any balance concerns here??.... Personally I'd install 2F rods and be done with that part of it.........
QUOTE: Shims on the main caps are very important. Ask me how I know. My understanding of it is that those caps were cast on the block, and then later cut off the block. This process removes material, thus making the hole not round after bolting the cap back on. The shims are needed to true the hole and set the proper clearance. If you run them too tight, even on the tight side of specs you could potentially ruin the bearings.
Wow this just gets weirder and wierder every day. Ok, yes the bolt heads are being machined so they have the right ¨stop¨to keep them from turning when torqued, and the head hight machined to be the same so they wont hit something (not likely), I was going to use the original nuts? The shoulder on the replacement bolts will be machined to match the originals. WISH I HAD ACCESS TO F2 RODS.. I will resize the rods to original specs then, oh and I´m going to balance them myself with a dremel.
Now on these main caps, are the shims at least the same size on both ends of one particular journal? Then possibly different from journal to journal? Well, I am thinking of just re-using the original shims on the mains, but can´t I just do the same with the block as the rods??? Thats a line bore right?
Thanks yall:)
Well, I found torque specs here on the site, but if someone could pass on just the cranks specs and tolerances it would really help as I don´t think they have these at the shop, I will probably need to provide them.
thanks again
Her ya go Man!... I've never found anyone that would line-bore one of these F blocks due to the dowels on the block side of the bore and each journal is a different size..... get yourself some plastigage cause you'll need it.......
Thanks alot for the data Grant, but huh? You have to be kidding me, this is really starting to give me a headache. I looked at the motor today and could only find like 4 of the original shims, since I thought they were trash and just flung em....:whoops:, live and learn. So, should I be looking for one of them nifty shim kits someone mentioned here ? Who knows... maybe these people will find a way to bore it, I´ll know tomarrow. WAPITFA!!!!
Thanks for the hep guys
The shim kits from Specter will be an assorted mix of used ones... If you run into trouble and can't find or fab some up let me know and I'll send you a batch.............:beer:
Each journal is a different size because they bored the first hole first, then passed through the first hole to bore the second hole and so on. So journal bores got smaller as you go back, and the increase in size on the forward ones was to allow the boring maching room to reach the next. It is possible to rebore these holes and true them up, but few will attempt it. I haven't read all of your posts Radish150, but I can't imagien this engine can be so screwed up. What prompted this tear down exercise anyways?
As long as you can slap it back together and it is even remotely in spec, I bet it will run for you. F engines are not that complicated. I do suggest you call Specter and get an early F engine manual, or any F engien manual so you have a clue what is going on with this engine, it will be very useful to you I think.
And one tip, don't throw away or loose anything when tearing down an engine, right or wrong, the piece was there for a reason, uninformed assumptions on what was supposed to be there and what shouldn't can spell disaster. The shims are nesecary and you will need them in some capacity. I'd start searching because they are pretty hard to get anymore.
Was down to the machine shop this morning ready to tell them about the different sized journals and such other problems and to my surprise they said they allready knew about that and not to worry... i then, thinkng of these ¨dowels¨asked if there were any other problems they saw and they said no. Soooo, i guess will just trust they know what they are doing, thier warehouse is fllled with work to be done from everything from motorcycles to ship motors the size of a camaro so I´m going to relax and let them do it.
Now just need pistons.... everything else has been sourced.
Cheers and thanks.
