Compressor not turning on
With all of the switches jumped were you able to get any sort of voltage coming out of the blue/white wire on the amplifier? If you were then there's either a break in the wire somewhere or the engine coolant temp relay is bad.
Thank you Jsloden! I'm going to double check all of the switch jumping. I'll check the voltage on the blue/white wire this time. Thanks again!
