compression testing guage
City that rhymes with fun
i just bought a gauge to test the compression in my F and neither of the fittings fit the spark plug hole. it came with a 14mm and 18mm. what size actually fits. these were the only 2 the place offered????
18 works for me.
what? theres no way that will fit. these are the only 2 sizes ive seen available. the threads look wrong also. what should i be lookin for then
well i went to my local parts store and they said it will be the 14mm, but the threads just dont seem right. thats all i got. anythnig will help!
Compare the fitting with the spark plug - the threads should mesh perfectly when lined up.
Also, measure the outside diameter of the spark plug threads, and of the fitting.
THat should give you confidence that you either have the correct fitting, or a complete mismatch, in which case you need to take the tool and the plug to the place of purchase, and demonstrate.
Kirk
yah i compared the fitting on the gauge with the sparkplug and gauge threads seem a little bigger. i dont know what thread pattern im trying to find? (fine thread, pipe thread, or whatever)
Do they mesh? Can you measure with a micrometer or calipers?
If they don't mesh, it's definitely wrong.
Sounds like you may have the wrong fitting.
Kirk
the threads on the gauge are bigger, the 14mm is the right one. seems like all you need is a finer thread.......... guess ill go back and see if they can help
yah nevermind my question im kinda an idiot!!!!
Bretty you're right about the 14mm
An F or 2F should be equal to or greater than 150. And a minimum of 128. But I know of good running engines with substantially less. The bigger issue is whether or not one cylinder or two are way off from the others.
