Composite LPG Gas Cylinders
flat earth Midwest
We just returned from a week testing the rig in Michigan's UP. Had a great time. The full 20 lb LPG cylinder we carried lasted all week, with plenty to spare.
Our LPG usage is projected to trend upward. The Mr Heater Buddy worked great, no more cold mornings or evenings for us! My old late 1970s water heater gave up the ghost at the last camp, so we bought a Camp Chef Triton to replace it. And while the old Coleman white gas stove and oven soldiered on, we pulled the trigger on a Camp Chef Oven/Stove after the trip, too. Both of the new appliances run on LPG, so we also added a Y-connector at the tank for cold mornings when we're cooking breakfast.:)
I've been thinking of going with a bigger gas cylinder from the beginning, but also wanted to go with a composite cylinder to cut down on weight and keep an eye on the gas level easily. Here's some background info from when they were first being introduced into the US market:
Composite Technology Pushes Cylinders to New Heights - NetComposites
Here's a FAQ on composite cylinders by one of the major manufacturers:
www.ragasco.com Frequently Asked Questions
Steel cylinders are available in a 30 lb size, which is about ideal as far as capacity. They're only ~24" tall, so will fit securely in my bottle rack without sticking up too much.
In looking into composite cylinders bigger than the standard 20 lb model, it seems that larger sizes are still somewhat specialized. There are 33 lb ones, but these are supposedly restricted to use on forklifts and advise not to use them with flame sources. They're also 28" tall, which is a bit higher than I'm comfortable with. My guess is that the restriction is more about restricting potential fire risk as much as anything, but who knows? Anyone know more about these? So won't work for me any way, but perhaps an option to consider for others.
I did come across a 25 lb cylinder though:
25 lb Propane Cylinder - Lite Cylinder
I'm liking it a lot, since it adds capacity over the smaller 20 lb standard cylinder. Too bad it only comes in white right now, but maybe if I hold off they'll get some more green ones? The price is reasonable, too.
I'm in no hurry to buy one -- next spring will work -- but I can definitely see the need for all the capacity we can squeeze into one cylinder on the tongue of our M101.
In any case, curious if anyone else has experience with composite LPG cylinders and has advice, maybe this could be a thread about them.
if yah got a rivet gun you can always pull it apart and paint it your fave color and put it back together eh...
Just a thought....
MaNu,
Seriously?:confused:
Now I am scared:rolleyes:
The things they do with plastic nowadays...
Naw, if I paint it, I'd just masking tape over the tank and spray away. No way am I taking something like this apart. It probably won't end well if i do something like that:p
Glad the trip was fun Mike...pics would be nice comma...:p
I ordered up 2 -20 lber's..thinking maybe I made a mistake and shot from the hip to early, but now based on the gas appliances, it was the right thing.
The drop in stove top requires a bb-q type regulator. Now I just ordered a 'T" to branch off to run the smaller hose (gas light)and larger hose (cook top) so that's the tongue bottle. This bottle will probably run the hot water heater for showers also.
For the 2nd bottle, that will also power a light, the table top grill, and/or the heater, and that runs off a propane tree. I know it's frowned apart to store the cylinder in the camper, but it will be secured, and theres's plenty of ventilation with the window cracked an inch.
Do you see converting over the white gas stove to propane? I know it doesnt get quite as hot, but with the first build it was the best thing I ever did...no more Coleman fuel to mess with.
So maybe another 10lber is the answer...sure will be easier to move and store, and leave the big bottle hooked to the bigger, less moved appliances.
Just a thought...:beer:
Pat,
For now at least, just not enough room on the tongue of the M101 for two bottles, so want to go as big as possible with the one I have. But that's a future goal and having two 25 lbers or whatever really will give lots of backcountry time with our rig.
I'm actually planning on a garage sale with all my old camper stuff next spring, so no conversion for that faithful old stove. I did put the replacement generator in it and it's perky now. We're really looking forward to using the wonderful new Camp Chef Oven/Stove. I'll probably keep some white gas on-board for the lamp, which is the schiznitz for reading, etc after dark and to power the back-up Coleman backpacking stove I have that uses it. I might consider a LPG light, but that's a ways off.
My back is kind of flaky, but going with a 10 lb cylinder might be in my future. I'll see, but hoping I never have to. I'll bet two 10 lb cylinders would fit on the tongue, but it just seemed that the two together (20 lb) would be too little for a total capacity for us.
Glad to accommodate your request for pics from the Michigan UP trip with the M101:):
https://forum.ih8mud.com/trailer-te...epmts-return-home-swimming-lake-superior.html
