Completely lost trying to figure out electrical problems
Birmingham, AL
Ok so posted here saturday, bought a 1992 LC from a wholesaler buddy of mine. "Ran when parked" (2015). He told me he started it and drove it on the transport truck and back off. Said all he felt was something not right with the axle but the engine and trans were strong. Told me his buddy (whose lot it was at) told him it needed a fuel pump.
No lights come up on the cluster at all. No Charge, No CEL, nothing besides the BRAKE light, the gear position light, and the door open light. The battery voltometer gauge works, none of the others appear to even move.
Got it back to my house and started tearing things apart. There was an aftermarket alarm and remote start I took out, the fusible links had all been bypassed (badly), most of the fuses had been replaced with 20AMPs, cut and spliced wires everywhere -- it was a mess.
I removed the aftermarket alarm and repaired all the wiring. I replaced the fusible links and put all the correct fuses back in place. I noticed that the contacts for the EFI fuse under the dash looked kind of black, but for now it tests good and they make contact. All fuses test good. I've verified power at the red/white wire going into the ignition switch and the black/green wire coming out and going to the fuse box. I swapped the EFI relay with one from the kick panel. Theres fuel in the tank, but I know it won't start without all the lights coming on. I've managed to get everything else working. Dome lights, headlights, windows, sunroof, blower motor, power locks.
The only things that I'm not sure about are: Brake lights don't work, and I can't shift out of park unless I hit the shift lock. There is no power at the CHARGE fuse under the hood. When I hit it with the test light theres nothing, but if I hook the test light to the positive terminal and hit it the light lights up. So there both grounding? At this stage, I'm not sure where to really go next. I've read all the threads, done all the suggested things, but so far the cruiser is just DOA.
I assume you have the EWD? I would just start at “power source” and work through “engine control” following all the recommend diagnostic checks. Be systematic about it and make as few assumptions as possible and you’ll find the problem. It’s most likely simple, so don’t panic and start ripping out stuff.
