For Sale Complete 1VD-FTV Engines and H152 Transmissions, Burnaby, BC, Canada
BiffS
Too many projects... ooh, look. Something shiny.
Vancouver, B.C>
Website
www.mekanix.ca
  1. 70 Series
  2. 100 Series
  3. 200 Series
  4. LX570
Burnaby, British Columbia Canada
We've got a shipment of 1VDs in stock that are currently in the process of full rebuilds.
Since this is a global site, do not automatically spam me with "this isn't legal in my state, etc". Offer void where prohibited, Some exclusions apply. Contact us for details.
These are built-to-spec ordered, so now is the time to choose your options. All are Pre-DPF.
The engines will come as complete as you like, with piping, wiring, and turbos, with ECU tuned to match. In all cases, these will be as "drop in" as possible, but you should expect that a SIGNIFICANT amount of effort will be needed to install them in 80s, 70s, or whichever series, unless you've done them before. There are some videos on Youtube about what's involved for the installation, so best to be informed before committing.
We offer installation at our shop here in Canada.
Currently we have:
1x 200 series twin turbo
3x 79 series single turbo
4x H152s, one without T case,
0x H151 (SOLD)
and more.
Your build incudes, at a minimum for the price below:
- Reflashed ECU for standalone use that deletes features that aren't necessary. Tunes based on requirements below. Automatic transmission deletes where needed.
- All new OEM bearings and seals
- All new OEM hoses under the valley
- New Starter
- New Alternator
- New AC Compressor
- New Timing Chains, guides
- New Glow Plugs
- Top end rebuild
- New pistons / rings: Overbore and stroker options available
- New or tuned injectors (for higher output applications)
- Power steering pump, vacuum pump, injection pump, coolant and water pumps, thermostats, etc.
- Turbo options: Stock or G-Turbo,
- New Clutch / Pressure plate (options available for high strength versions)
- Harness with needed accessories such as injector drivers, etc
- Full body harness and LHD swap options available
- Full stainless exhausts available, depending on the model
- We recommend front mount intercoolers wherever possible, versus the top mounts, so this is a point to discuss at the time of ordering.
Packaged and tested for shipping. Prices start at $23,000 USD for complete engines, ready to drop in. Matching H152s with transfer cases $5200
Timeframes as based on the build options and availability of parts.
Plenty more photos available.
The 1VD combo makes me drool but the amount of wires on top make me scared.
My double cab 79 is a VDJ body….maybe I should pivot from my FTE….amazing work!
You most definitely should... The only reason that I've split the wires up like that is because the donor harness had some of the igniters cut out of it and a few other things. And I need to flip half of the harness over because I've made the truck left hand drive
