Combustion leak test question
Virginia
New Guy greetings from VA! Yes I searched and yes I watched all the you tube videos....I just bought a 97' (with front lockers yeah me) with no apparent issues and decent maintenance. Just for reassurance before I start dumping money into refurbing it, I decided to do combustion leak and compression tests. The only tool I could find local was the Lisle single chamber with a vacuum line, no pump bulb. The first time I put it on with apparently the wrong attachment (the one meant for the bulb) and it filled up the chamber with coolant, turned yellow, and freaked me out....I'd call that a false positive. I switched vacuum attachments to the other with a little hole on the side of it. This time nothing.....not even a bubble pulled through. Thinking the vacuum was not enough I slowly put my finger over it to create more pull and get some bubbles going. Did this for about 30 seconds and it stayed blue.
I did this twice today and got the same results even though the second time I pulled a little coolant in it still stayed blue. Has anyone else used this particular tester that didn't come with the bulb and used a vacuum line??? Did you get bubbles??? I am worried about a faulty tool. Looking at the front of the engine, I hooked it to the small vacuum line at the right end of the intake. I planned on Blackstone test but the previous owner JUST had the oil changed so I have to wait. Hopefully I'm in the clear and can start burning my dollar bills. I am going to do it again tomorrow afternoon to see if maybe driving it awhile will build up the pressure again if anything is wrong. Any info would be greatly appreciated!
