My 70 FJ40 has a transplanted 2F with a Weber carb. It runs great when it's warm, but when it gets chilly it gets lean (I think) and "spits" through the carb. Smarter people then me have stated that this is caused by freezing due to venturi forces in the carb and the lack of the factory heat riser. I've tried to make a riser that takes heat from the header where it gathers to 1 pipe and goes to a plate around the air filter. In effect, almost all of the air into the carb comes from around the header,
This helps, but I still get spitting when accellerating or if I get back on the gas after coasting down a hill. It's a serious PITA in the winter. Anybody have a solution?
Thanks,
Gene
Thanks,
Gene
