Cold weather brake issue
We have been having some really cold weather, high of 8 degrees today. This seems to be causing by brake light to be on until the truck is really good and wormed up. Also, there is very little brakes/assist on the first push or two of the brake peddle when it is really cold.
Has anybody experience this? Is it time of a new master cylinder? This is a 97 LX were talking about.
Thanks
Check your brake fluid level. IIRC, a low fluid level will cause the brake light to come on.
Does your pedal make a fairly loud "whoosh" sound when you first press the brake down? Mine does, but I'm not sure if it means something is wrong or not. I can't remember if it has always done this or if I am just observing things more closely.
The no brakes-when-its-cold effect is probably the check valve in your booster freezing up. It's in the 4 inch tube coming out of the front of the booster. Replace that before you rip into the MC. When mine did this it didn't affect the brake (idiot) light, but I had no brake, with very firm pedal, until it warmed up.
I've had the cruiser parked outside the last few nights. When I leave for work in the morning I have also had the brake light for about five minutes or so. I'm no where near your temperature, I think we have been in the 40s at night.
I'll double check my fluid level, although it was fine last weekend.
This is exactly what has been happening to my FJ60, 1986. Temp is 20s, and HARD brakes, my wife couldn't use them. After 10-15 minutes, soft but firm brakes are back and I stop well.
Ordered a new check valve and hose from SOR
doug t
doug t
Installed new check valve, but still hard brake in the cold morning. Need to check the metal "U" pipe that the vacuum connects going under the MC, it might have fluid in it. If not, then must be the booster. 194k on the rig
doug t
Mine does the same thing, its like -5. Brake light on for about 5 miles of driving, then off.... To lazy to check the level, I am sure something in the dummy light is just sticking. Brakes are firm like they should be and it so far stops.....
I'll update if the fluid was low when I pull it in the shop this weekend to change the oil.
