I've noticed this winter that my 96 doesn't want to shift into OD until engine temps hit 130F. It's like clockwork...ultragage hits 130, tranny shifts. I know the trans fluid needs to warm up. I assume this is normal....thoughts?
There is engine temp sensor specific for the tranny. Yes it locks out OD under normal conditions. Under certain fault modes/error lights it does by pass this function.
Thanks Tools. I should have looked in my FSM. Oh well, now it's here for someone to search....and yes ultragage reads 131.7 when it shifts every time....so my truck is right on the money.
So one question I haven't been able to answer is if you unplug the sensor will it bypass this function ad allow OD shift at all temps?
I did a diesel conversion and thought I was going to have problems with this function. I broke the tranny temp sensor on my final installation ordered a new one thinking I would need it. Drive it the first time before installing. OD shifts with out input.
I haven't been able to confirm if this is because to computer is stuck in a fault mode that allows OD shifts or it it is the temp sensor alone.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
