Cold Start High Idle
TX
When I first start the LC in the morning, the rpms immediately jump to around 1800-1900. When I shift from park into R or D, they immediately drop down to around 800-900. There is no high idle in neutral and the idle rpm does not jump around - just really high during the first start of the day. It doesn't do it during warm starts, meaning after I've already driven some during the day. It also doesn't do it when I start it in the middle of the day, just the first start in the morning. Yes, it is colder here in the morning but it seems to do it during warmer weather as well. Is this normal?
normal, its trying to warm up. If you notice most all cars do it.
Thanks. I just wanted some reassurance from other 80 owners that this is a normal occurrence and nothing is wrong with my LC.
The problem i have with this situation is my lc didnt do it prior to cleaning the throttle body and removing some of the components to do the job.
This extremely high idle is presenting some bearing noise the first second or 2 prior to the oil pressure jumping up. Can this be adjusted with the round unit on the front of the TB?
There is no adjustment to the IAC (Idle Air Control, or round thing), it is a stepper motor controlled by the ECU.
Mine does the same thing, straight to 1800-1900 or so. And yeah it sounds like there's a bit of a rattle for a second or two as oil pressure ramps up. More likely timing chain than bearings I think. I don't like the sound but it's not under load so I'm not too worried.
There is a mod out there where you use o-rings on the stem of the IAC to reduce how far it opens. I tried to get the IAC off but with the philips screws on the IAC motor housing (why phillips? grrr) I could not remove the unit. Seems like I need to get the intake off to do it and I'm not willing to go that far. Here's a write up on it:
On the 93/94 that rattle is likely the Pulse Air system that you are hearing. Easy test is to disconnect the vacuum line to it and see if it still does it.
This line is the one to disconnect.
