cold idle problems
When i first start up the car with the engine cold the engine runs rough at around 500rpm almost cutting off until it builds up to normal rpm. Runs fine at over 1500rpm. When the engine is warmed up it runs almost perfect, it has maybe a 20-50 rpm fluctuation warmed up. Sometimes after first starting it up when it has only been parked a minute or two the idle will run high and fluctuate up and down alot. Can this be from a bad egr valve? Or what else should i look at? It is a 91 with 3fe
check the giant air hose for cracks that goes from the air filter to the engine. Next look for a loose vacum hose under the head. If this doesn't show the problem check back.
Verify that the cold start injector is working and the cold start injector timed switch is within specs.
good luck
