cold idle and power problem
Ok yesterday and the day (about 20f & 38F out) I started the LC let it idle for about 2 minutes. After about a minute and a half the idle started getting rough. Then I take off down the road and I have no power above like 2000 RPM's. I think it would clear out if I gunned it but I've had the wife in the car and I don't want her to think there is anything wrong. I do have codes P0141,P0135,P0125. I guess I need a couple O2's. But I didn't notice the problem last month, and I still had those code. It just wasn't this cold out.
The O2 sensors seem to have more issues when it's cold out. The :princess: truck was only throwing O2 codes when it was cold.
If you're getting O2 codes then that is at least one of your problems and the most obvious one that needs to be addressed. I would swap out the O2 sensors and see what happens. I would also check to make sure you don't have a plugged cat as that could cause some problems (and premature O2 sensor failure).
Checking the resistance of the O2 sensors will be the easiest way to test them. Disconnect the plug harness thing and stick an ohmmeter in there. The factory service manual will give you the acceptable resistance, but if you don't have an FSM, I can give you those values if you have a 91-92 (maybe the sensors for 93-up are the same?)
