Cold feet
Adair Village, Oregon
Hey, you guys were so helpful on my last post (birfs) I thought you'd like to check out my new problem:
To whit, on my 1991 FJ80, after the vehicle has been on the road the better part of an hour the heater will start pumping out cold air, the temp gauge reads as though the vehicle is off, and my gas mileage nearly doubles (some problem, huh?). I have not played with the tstat yet, but planned to until my wife said, "Wow, we just came 200 miles on a half tank, that's great!"
Is there a potential down-side to running cold? The problem is intermittent. Anyone, anyone?
Whatever the problem is I want it. I have 110 and can plug in a space heater :p
If you're pumping cold air then you've got a blockage in the heater core or cooling system, or an air pocket. This is not something to ignore. Could be a radiator hose is so old it's flattening and stopping flow to the heater. I can't think of a thermostat being the issue but I'd immediately do a full cooling system service - new thermostat, coolant and use a system cleaner to do what you can. The MPG thing is odd, though if you WERE going only 100 miles on a half tank at freeway speeds then something doesn't compute there either - that's 12 gallons to go 100 miles and unless you're either driving fast, have large tires or a lift or all three then your truck should do better.
DougM
With the cooling prob, Definitely look into that! That could create some expensive problems.
~100mi to the half tank was my average with 33s before the regear....I can believe it. But how those two things are related, I have no clue. I've ran with and without the thermostat, and I get worse mileage without it because running cold means the cold start injector is pumping in extra fuel.
Sure sounds like a busted t-stat to me. :meh:
No advantage to running colder than Toyota intended. And highly unlikely you're getting better mileage due to that. One glance at the gas gauge and saying "Hey, look how far we've gone" isn't even close to an accurate mileage calculation.
Replace the t-stat, and don't forget the o-ring that sits on top of it (and install it carefully) or you'll still have cold feet. :)
Curtis
We've had the truck a long time, the wife drives it regularly and she's obsessed with mpg so she knows with erie precision what mileage she gets (14) and what mileage I get (10 on the button) with our driving habits so over 18 (what the next fill revealed) is the greatest thing ever.
Assuming the two are unrelated (new wheels and tires perhaps?) I'll service the cooling system and get back to yall.
One tank and
"Hey, look how far we've gone" isn't even close to an accurate mileage calculation.- from CJF.
X2 - get cooling system fixed so you can have the option to "fix" the mileage "problem". High mileage prolly just a fluke or mis-calculation.
