Codes 2 and 8
Colorado
My 1994 Land Cruiser has the check engine light illuminated, so I pulled the codes and per the code list here on Mud I get code 2 Air Flow Meter signal and code 8 Intake Air Temperature Sensor signal.
Per my manual, resistance from E2 to VS should be 200-600 ohms, and it is ~2500 ohms.
E2-VC should be 200-400 ohms, and it is ~2500 ohms.
E2-THA is about where it should be for the current temperature at ~1500 ohms and 75º outside.
So I think I need a new unit, but I'd like to ask if there's another test I need to do before I install parts?
Is there a way to clean these up and give them new life?
Where's the best place to buy OEM replacements? Beno?
The 93-94 airflow meter is manufacture-discontinued and is no longer available. You will need to look for a used one and it needs to come from a 93-94. The last published price on that part was just shy of a thousand bucks.
Ouch. Thanks for the info. I saw a re-man for around $300 on a website. Is that a good price? Is there a source for the parts so I can re-build it my self?
If I get the new maf, will that also take care of the air temperature sensor?
I ordered a re-man Cardone air flow sensor for $186, and it should arrive this week.
I'm still unsure-will this also take care of the air temperature sensor issue?
