Code P0420 - need advice.
I have a 95 fzj80. I've been getting a CEL for the last 1000 miles or so. It comes up and I clear it and about 200 miles later it comes up again.
So I pulled the codes and I get:
P0420: Catalyst system efficiency below threshold: Trouble Areas: Three-way catalytic convertor; open or short in heated O2 sensor circuit; heated O2 sensor.
Where is the best place to start with these symptoms? Is there any way to tell which o2 sensor is throwing the code?
No only had the truck for a couple months. Is there any way to tell which O2 is throwing the code?
Just do them both. Per FSM, they are only good for 80k mi. I doubt the previous owner did them. I did one at 115k mi. due to a code, and just replaced both last weekend at 193k mi. while doing plugs, cap and rotor. The truck runs better than ever. There are whole threads on getting improved milage and smoother idle after doing nothing but the oxygen sensors.
Call CDan and place an order !!! You'll be happy you did. FYI, hit the nuts with some PB Blaster before trying to remove the old ones. Let it sit for an hour, if your truck was from dry country, and a day if it wasn't.
R.
