Code Alarm Programming? Any CA dealers out there?
St. Louis, MO
OK, its tech and its on MY 80, but it may not be overall 80 tech - so the mods can move it to a more appropriate place (I just couldn't find that place).
I had a CA670 installed in my '96 cruiser when the factory system started to die. I mostly wanted the two-way LCD transmitter with remote start - and I love the thing.
My original transmitter started to die though so I purchased two more from an on-line retailer for about $70 each (better than the $110 my local guys wanted plus another $20 to program). The instructions that came with the new transmitters indicte that programming simply requires holding the button on the system (inside the truck) for 10-seconds to put the system in programming mode. The alarm and horn are supposed to sound briefly to indicate it is in programming mode. This doesn't seem to work on my system no matter how long I hold the button. Any ideas? I'm hoping there is a code alarm dealer on the board somewhere.
I talked to my local dealer who installed the system for ~$1,000 last year, but they seem to be having financial problems and keep jacking up the price (he now wants $100 to program the remote since I bought it elsewhere). And the 'lifetime installation warranty' now doesn't cover the problem with putting the system in programming mode - he wants $55 an hour to look at that. I guess I should have just went to a big-box electronics store instead of trying to keep my business local.
Sorry again if this is not the correct forum, but thanks for any help!
Code Alarm remotes always program like this:
Open driver's door.
Turn ignition key to 'On'
Press and *hold programming button* in (see diagram, button under dashboard)
After 15 seconds the the door locks will cycle 3 times. Do not release Programming button
Press lock (left) button the remotes to be programmed. The door locks will cycle one time.
Exit programming mode by releasing Programming button under dashboard and turning key to off.
Code Alarm Programming Button is under dashboard on the kick panel by the driver's left knee, left of the steering column. If you can't find it, it might still be tucked up in the wiring harness higher up in that same general area. The botton is recessed in a plastic ring
Oh, and make sure you are not pressing the brake pedal at all during the procedure.
Try it first with the driver's door open, and if its not programming, close all of the doors and try again.
Thanks a ton Cody!
The directions that came with the remotes are exactly as you stated EXCEPT they omit the part about turning the ignition to 'on' which seems to be important :)
I figured I just mis-read the directions after I saw your post, but I double checked and the directions are just wrong. I'll give it a try when I get home tonight (in the very cold weather :frown:).
Now I just need to figure out how to use all the other features the dealer/installer didn't tell me about (but I found listed on the web).
Thanks again!
