Code 71 Only When Running 87 Octane in a 1994
Comaville in the Midwest
Been running E85 for several tanks (>2K miles) with no codes. The E85 pumps were running slow the other day so I switched back over to unleaded regular 87 octane and after 20 miles got a code 71. I cleared the code by removing the ECU fuse and drove on. After 50 miles I got a code 71 again. Did a clear again and got near the bottom of the tank (~200 mi) before code 71 again. Switched back to E85 and no codes after 500 miles. Has anyone ever noticed this behavior in a 1994 Land Cruiser?
I'll fill up with 87 octane regular again and trace the problem soon. It runs fine on E85 but I get lower miles per tank (~10%) and it might idle a bit low sometimes when it's really warm outside >90F and feel a bit sluggish on acceleration. I also ran a tank of ethanol free 93 octane unleaded without any codes.
I think running E85 is a horrible idea in a vehicle that wasn't designed for it .
You can defeat the code 71 with a jumper wire, I'd just do t
(Up to) 85% ethyl alcohol mixed with gasoline. I guess they don't have it up north. It's cheaper than "real" gasoline but has less power in it. Basically watered down gas.
E85 is 85% alcohol, the LC was definitely not intended to run on it. Bad things are in A2ShedsJackson's future, I fear.
Code 71 is an EGR system malfunction.
I have not seen it here, yet that does not mean that it does not exist. Some brands do put ethanol in their gas, I do tend to avoid the ones that over advertise ethanol in their gas (Yet probably everybody does anyway).
There are some reports of bio diesel use in the summer in certain provinces; which I have had first hand experience with in Europe; which I feel is a neat idea.
Alcohol (ethanol, methanol) is regularly added to gasoline in large metro areas with air quality issues, but for standard use is generally less than 15% of the total volume. E85 is a whole different fuel, and is only supposed to be used in vehicles that are designed for it. There are usually warnings on the pumps to that effect.
Alcohol is more aggressive than gasoline, and can eat rubber parts on vehicles that weren't designed to run it. It is an excellent cleaner too, and can dislodge gunk in older systems, which sounds great, but ends up causing problems. That could be what happened to the OP's system.
Alcohol has significantly less energy than gasoline, I'm surprised your MPG only drops 10%. Typically it's more like 25% in a vehicle designed for E85. At that loss, the fuel would have to be much cheaper to be worthwhile. Not to mention the frustration with lower horsepower.
Non-polar solvents contain bonds between atoms with similar electronegativities such as carbon and hydrogen (hydrocarbons, such as gasoline). Bonds between atoms with similar electronegativities will lack partial charges; it's this absence of charge which makes these molecules non-polar. Gasoline is a mixture of hydrocarbons, including hexane.
Gasoline (non-polar molecules) and water (polar molecules) do not mix because the nonpolar hydrocarbon molecules would disrupt the water in such a way as to produce a structure that was actually lower entropy; therefore, the mixture is less likely to exist than the separate liquids.
Ethanol is a very polar molecule due to its hydroxyl (OH) group, with the high electronegativity of oxygen allowing hydrogen bonding to take place with other molecules. The ethyl (C2H5) group in ethanol is non-polar. Thus, ethanol can dissolve both polar and non-polar substances. This why flex fuel vehicles will be sure to use components that come in contact with the fuel that are compatible with both non-polar and polar solvents vs just polar solvents in a non flex vehicle. ECU tuning is another issue.
More info on solvents and polarity here:
All about Solvents: Non-Polar, Polar Aprotic, and Polar Protic Solvents — Master Organic Chemistry
Chemical polarity - Wikipedia
Nah, the code 71 has started to appear randomly even when back to regular or premium with <10% ethanol ( Ethanol - Wikipedia )
Maybe it's just haunted. Yah gots any spells you rekon might work to gits the bad juju out?
Just delete the EGR. A jumper wire will keep your CEL off, and if you don't have inspections where you are, you're ok!
