Code 71..I know, but I have a question
Boise, ID
I have a code 71 nearly all the time in town. If I clear the code it stays off for a day or two. The weird thing is if I leave on a road trip with the cel on, it will go off and stay off. I only get the code around town. I can drive for hundreds of miles on the highway or freeway with no code. Anybody have an idea what would do this?
Have you changed anything on the EGR system? Replacing the modulator got rid of the 71 on my '94.
I am just guessing, but I think that the consistent heat generated at highway speeds may stabilize the EGR system and temporarily see no code.
Once again, just a guess... Start with a full inspection of the EGR and go from there. Cleaning the heat sensor (I think that is what it is called - it is right below the modulator) would be a free thing to start with.
Riley
Mine goes on when I'm in town, or just starting to drive somewhere, regardless of if it's a far away place or not.
When I drove to LA and back, it came on after I got gas, as I was getting back onto the freeway.
I'm replacing the modulator, and hopefully that will fix it.
I did clean my temp sensor, and it was carboned up pretty good, but it didn't change anything. I put 250 miles on the thing today with no light, but only about 15 of those were in town. I think temperature is probably a cause as well, but it always runs about the same on the gauge.
You have a 3FE and I'm not sure what the differences are but after tackling an EGR code on a 1FZFE I would proceed as follows:
1. Clean the temp sensor.
2. Examine the modulator. Is it black with carbon? If yes, plan on replacing. Whether or not it needs replacing you still have to proceed to the next step, cleaning the TB, all passages, replace all vacuum hoses. Why? Because if it's black with carbon there's a reason. If it's not black with carbon then there's something else causing the issue.
3. Remove and thorougly clean the TB with TB cleaner. Clean all passages, ports (including the three small ports that exit near the throttle plate). EGR or not you want to clean the TB.
4. Before reinstalling the TB, remove the VSV for EGR and test it per the FSM. Resistance test is first and easiest. Replace if it doesn't pass.
5. Replace all vacuum hoses. Also easy to replace the forward coolant bypass hose while you're at it. Rearward takes a little more effort.
6. Enjoy a beverage of your choice.
7. Reinstall TB.
8. Still no dice? Move on to the EGR valve.
This is based on my experience and I feel like it's a logical way to approach it. In my case I didn't find any carbon in the modulator, the TB had very little carbon in it, but my VSV measured open circuit rather than the 30-something ohms specified in the FSM. Replacing the VSV and stopping at step 7 has so far done the trick.
7. Reinstall TB.
Shouldn't you also suck/blow into the modulator to see if air actually goes through?
