Code 71 EGR Issues
MA.
I recently had a check engine light reading a Code-71 which has to do with the EGR. I cleaned the filter, checked for blockage, re-installed and cleared the reading. After 30 minutes of driving, the light came on again. My 94 has 160,000 miles on it. It runs fine and I haven’t noticed any difference in fuel consumption. Has anyone had to deal with this one before?
Yup, There is a recent post here about it, I get it every once in a while, Especially when its very cold, I have replaced the green or blue topped valve part and did the "suck" test on it(good) as well as cleaned the Temp sensor.
It stays on for a day or so then turns off, I notice it happens more when my wife uses ours for errands...I tend to warm it up for a min. or so, Where as she starts and goes.
Im sure it could be any number of things...
Good luck
Yep,
I just got a code 71 as well. Happened within a hundred miles of me cleaning the throttle body, IAC, MAF and replacing the PCV. Also replaced the o2 sensors for a code 28 within 300 miles before the code 71.
I'm not too concerned at the current time, but I will be trouble shooting in the next month. There is a lot of information available in the FAQ at the top of this forum. Start there, its a common issue apparently.
brad
Thanks guys. I did some searching and and found the most common culprit is the VGR Vacuum Modulator (can't help but think of the little Martian form Bugs Bunny when I say that one). If a good cleaning of that doesn't help I'll replace it. It's a $50.00 part if you know where to go, which around here appears to be C-Dan.
Thanks Again.
