Code 41
Boise ID
Ran diagnostics on my 93 1fz-fe and it pulled up the code 41 which was the TPS sensor or circuit or the ECM or circuit.
I replaced the TPS and nothing changed still acting the same and checked the wires that go into but was wondering what else is in that circuit to check.
Also could the ECU be going bad. Reading on here it throws the codes in the 80's if it is bad not the 41.
Anybody else had this code thrown and what solved it. Might be looking for a good landcruiser shop in the seattle area if I cant figure it out so suggestions would be great for that.
I had code 41 in conjunction with the 81,82, & 83 codes that are supposed to indicate you need a ECU. I bought a used ECU of the right vintage, still had code 41, so I replaced the TPS and all is good. Does your TPS pass the test sequence in the Factory Service Manual? It might just be out of whack a bit. It's easiest to adjust with the throttle body on a workbench. On the flip side, I never experienced even the teensiest bit of running wrong, even with all those codes. I'm convinced one could drive forever with that set of codes flashing with no ill effect.
