code 340 and strange engine behavior
Maybe someone can help me identify what has started happenning on me 1995 fzj80. Problem only happens when the car is warmed up to normal operating temperature. It will stall or loose power for just a second if the throttle is pressed too far, but if I back off the throttle it wont happen. All of the lights on the lower portion of the dash blink off and then come back on as if nothing has happen except sometime the check engine light stays on. When I check the code it is 340 (crank shaft sensor in my book.) Any suggestion or past experience that can help. Thanks in advance.
Roy
