Code 28, O2 sensors and CEL
London, UK & Lusaka, Zambia
Hi guys, just after picking your brains if I may...
93 4.5L petrol auto,
old ECU was a 60160 (even older than the 60170 I was expecting), just swapped today to a 60221- sourced from a boneyard in Seattle, WA, via ebay, posted Friday, in my car today - man the world is a small place :)
Old ECU gave codes 84/85/86, hence the swap. Pretty sucessfully really, those codes have gone, take off from a crawl is smoother, and gear shifts are noticably better.
Old ECU also had a code 28, which I gather is sub / secondary O2 ? No CEL though.
New ECU gives me the same code, but with a CEL !? Obviously I need to fix the sensor, but I guess the new ECU is a bit fussier about emissions than the old and decides I need a CEL !
Does the fact that ther CEL illiminates change the mode of operation (e.g. baseline paramters, or "limp home") ? Certainly seems better than before, so I doubt it.
Main question is about the sensor - where do I look ? I found one immediately in front on my cats (or rather, cat replacement pipes - pretty common over here, and legal). Which one is this , primary secondary ? Where's the other ? The daig box has pins marked for the 2 sensors, so I figure is does have them someplace!
Many thanks in advance - JB
