Code 28 Fix ?????
Hi....I have a OBD 1system 4.5 1FZFE cruiser and it seems to be running to rich, so yesterday I did a fault code check and it gave me a code 28 "O2 sensor". I did alot of reading about the subject and went to test the voltage that the O2 sensors are producing.
They both started around 0.45V and then jumps to 0.90V and then it settles on 1.1V and it stays there....this is at idle speed on operating temp. I did not have anybody with me to be able to test the voltage reading when accelerating.
It seems that 1.1V is very high and it means that the LC is running very rich.
What can I do to fix this?
Can the sensors be cleaned?
What replacement sensors can be fitted? "OEM will be expensive"
Will fitting new sensors be a sure fix?
The Catalytic converters have been removed ages ago
I have checked the readings on the diagnostic box aswell E1 to VF1 reads 0.07V at idle and 1.1V at 2500RPM, E1 to VF2 reads 0.07V all the time regardless of idle or higher revs.
I see that in the front of the exhaust there are the two O2 sensors left and right, but a bit further back on the exhaust there are 2 more sensors "exhaust gas temp".....do all 4 of these sensors work together to handle the air fuel ratio for the EFI system?......the front 2 sensors have 4 wires and the rear 2 only has 2 wires so how do I figure out what sensors needs repair or replacing???
Thanx
Rickus
