I am having intermittent rough idle and code 26. I am on the road, in Phoenix, AZ right now.
Like some of the others the problem started after I hosed down the motor and underside with power washer. Lately, when I wash the motor and spray the dist. the motor will either die or run real rough but will run fine after I drive for a few miles.
This time was the same but the check engine light came on and off. I resat the code and took off on my trip to Vegas. On the way the motor started to run rough. Thinking it was bad gas from UT, I drove on and filled up a couple time in Vegas and went on to Phoenix. The rough idle is getting worse. It feels like its going to die but then will run fine for a few minutes.
I dont have my FSM and being on the road, I don't have full use of internet.
Where should I start looking to fix the problem?
I also check the timing before I left. For some reason the timing was about 12 deg. advanced and it ran fine. Don't know how it got that high. Last time I set it it was at Factory setting (don't know how long ago). I set it this time a about 3 deg advance.
Could the change in dist cause this or it being advanced hide the problem? I think not as I had no codes before I washed the motor.
