Code 22 Engine Coolant Temperature Sensor
Bend, OR
Hello all,
I'll start with intro and go from there.
Name is Evan Williams (yes, just like the whiskey).
Live in Oregon.
Have a '93 80 series (locked up)
Body has about 235,000 mi. on it and the motor and tranny were transplanted from a cruiser with about 165,000 mi.
Before and after pics included
Tundra 16" steels, 1 1/2" spacers and 33" Toyo Open Country M/T's. Needs a lift.
My issue is a code 22 which is the Engine Coolant Temperature Sensor.
It hardly starts and it idles rough until it warms up, then it runs OK, but not quite.
A shop changed the temp sender while doing some other work and it obviously didn't solve the issue.
I've now taken it into my own hands and subsequently putting into yours to help me solve.
Ideas?
Where is the Engine Coolant Temperature Sensor? The 2 wire one.
Thanks,
That helped a lot. The plastic part on mine broke off and all you can see is metal bolt part. Hard to identify. I kinda figured it was close to this area because I had an extra plug coming off the harness that looked clean unlike a spare plug.
I will try to get some pictures for your viewing pleasure.
Off topic, but thats a nice looking 80. It would look really good with those side steps pulled off of there as well. On topic, when you get your sensor taken care of you might consider a KOSO to keep an eye on things.
I agree with you. They're coming off soon.
Glad to help. When pulling the old and installing the new......be careful of the knock sensor in the same vicinity........I broke mine off with my manly brute strength !
Got it done and it RUNS!
Thanks all for the help. Knock sensor already repaired. that's partly why I had to replace the coolant sensor; it got broken in the process.
Years now after the last posts on this thread.
I had the code 22 for the ecu temp sensor Pop up on the way to Denver the other day. Didn't make a difference in how it was running .... Until I finally came to an idle, just a bit rough , drivable still.
Bought a new sensor and replaced it ( after clearing the code and having it pop back up instantly ),
New sensor not the issue.
Had an electrical friend of mine over enjoying. A beer, and began the process of testing resistance and such.
Pulled the plug off and lo-and-behold, 1 of the 2 wires was off the back of plug. I obviously missed that when I put it back on ( or tore it off while changing , and code will remain after replacing pig tail.
I just ordered one from eBay and we'll see ... Couldn't paste From my phone, search eBay for Toyota coolant temp sensor repair pigtail 158-0421 (Which the beck p/n for the sensor )
Tnx
