code 21 noob
Fair Oaks, CA
Hi,
long time lurker..- first time poster.
93 LC (9/92 builddate) 130k miles
CEL on first time in 3 years. Code 21 only with paperclip method. Front O2 sensors replaced approx 5000 miles ago. I dont think the OBD1 cars have an after the cat O2 sensor?...
ECM upgrade to the expensive replacement (the 60221) verified. She has always been stinky rich in the morning, but passess smog easily when warm. The CEL wont go out resetting the battery or pulling the EFI fuse. Runs fine, except for 10-11mpg as always.
Any suggestions from the mud braintrust?
thanks
Shawn
Hi,
You have two O2 sensors. Parallel on the exhaust, just before the two parallel cat's. One of them is the "front" or #1 sensor in that it's on the downpipe for cyl's 1-3, the other is the #2 sensor.
I don't remember offhand which one code 21 refers to; you'll need to figure that out. Also, you should definitely figure out which one was replaced; don't assume it's the older one throwing the code, as the newer one could be defective.
Most folks replace both at the same time. If you do you're likely (but not guaranteed) to see a noticable mileage increase.
Welcome,
Curtis
CJF thanks for the reply.
I suppose I should clarify that both front O2 sensors were replaced by me about 5k miles ago. BTW, I did not see an increase in mileage, and never had a code before I changed them. I was at about 125k miles and saw it as maitenence item.
Just need to know what code 21 is and why my computer wont reset. Cant get the beast smogged in Cali with a CEL.:doh:
It's definitely an O2 sensor code. (Somehow from your post I accidentally assumed you knew that and were looking for further advice.) I don't have my FSM here though, so I can't tell you *which* sensor code 21 is for.
Keep in mind it could be a wiring issue: get under there and check out all the connections, and whether the wires are rubbing on anything.
As to why your computer won't reset: Might also point to a wiring issue, so the computer immediately senses a problem, rather than not until the rig's been run for a few miles.
My '93 is doing the same thing, I just replaced the sensors about 4000 miles ago. I plan on checking the wires with an ohm meter and if all shows good, i will order two factory O2 sensors from Dan. (the ones that are on there are aftermarket Bosch)
Mine are the NTK with the correct end, not universal ends. Some info I've come across says code 21 is bank 1 O2 sensor, and other publications have just O2 sensor. Which side is bank one? Im gonna pull both and test them with the propane method. If they come out functioning properly then its the wiring or the ECM I guess. I have to admit the LC has been brutally reliable so I suppose I'm due for something like this.
Shawn
...I have to admit the LC has been brutally reliable so I suppose I'm due for something like this.
"Brutally reliable" especially with 100% of your posts being in this thread in 1.5 years of membership! You must be a true "SEARCH"er. That button has taught me more than I've ever needed in 3+ years of searching!
Ha... yah, not much of a post whore! Search is good except when the term you need is only two letters then it doesnt help. I guess I will start my quest on cyls 1-3
thanks
84runner, I went to college in Fresneck and used to hit some of the trails in Auberry.,worked for the US Forest Service in Dinkey Creek up near Huntington Lake. Beautiful place.
Bump Ive got a CEL 28 #2 o2 sensor was wonder is there a way to convert this to just a single o2 system instead of parallel im thinkin about movin the cat to gain more room in that area and puttin a Y so i can use a single inlet for a cat
any thoughts or comments?
tkx
ben
I'm actually a recent transplant, 04, to the 'No.' Im originally from San Jose, basically the same just way further away from the beach, a lot colder in the winter, and a lot lot lot hotter in the summer!
You still doing the fire thing in Fair Oaks? I'm a FF in Dublin, east of Oaktown...
