Code 21, #1 O2
MN physically, MI spiritually
Help... :mad: In the manual there is talk of heated O2 sensor circut along with the heated O2 sensor... What are they refering to with the heated O2 sensor circut? Is there an external circut hidden in the harness somewhere? I cant decifer anything from the manual or see any other callouts to the sensor circut. Any help appreciated.
94 model year.
Edit:
Did an ohms test with the meter set on RX1K and it came up 9 ohms. (The meter goes from RX10K, RX1K, RX100, RX10, RX1) There was no response on any other setting except to bury the meter at the RX100 setting.
Question one, was the RX setting correct ?
Question 2, is 9 ohms to high as the manual states proper reading between 5 and 6.5. I think yes but let's hear your two cents please.
They shouldn't have failed that fast. My '94 burns thru O2 sensors about every 60K. Just replaced mine again last weekend. Check the wiring harnesses on the vehicle side above the molex connectors. Are any loose or broken? Are the molex connectors themselves loose? I had an issue a looong time ago where one of the wires above the molex connector had either been cut by the stealer or just plain broken. I can't make heads or tails of that section of the FSM either. I was also under the impression that on our OBDI models that we couldn't distinguish which sensor had gone bad. I've always just replaced both of them. Relatively easy job here in SoCal without rust on the threads!
I traced all the wires all the way to the main harness and they are all intact and in almost perfect shape. The connectors are near perfect as well. I am going to order a new #1 and punt. Seems like it is a bad part.
Thanks for the input.
Code 21 in the FSM shows #1 Heated O2, Code 28 Shows #2 Heated O2.
:whoops: Guess I could have just replaced #2. I replaced both anyway. With my history of O2 sensors I'd have been replacing #1 soon anyway! I've had mine replaced once on the recall, once by the dealer and now twice by me.
