For Sale CO 2001 BMW Z3
Status
Not open for further replies.
Grand Junction, CO
Was planning on waiting till spring to post this up, but I figured I'd get the ball rolling early. Thought it'd be fun to have a little car to zip around in. And it is, but life in the fast lane just isn't my style. I prefer puttering along in the right lane.
It looks like it's never been driven in the winter before-the underside is extremely clean. No rust anywhere, all bolts are easy to remove. Car was taken care of pretty well before I brought it. I did spend a fair amount of time and money fixing things that they had let slide. I thought I'd keep her for a few more years, so I didn't mind.
$6500 or would love to trade for a 100 series or a 4th gen 4runner. Willing to add some cash on top for the right one.
2001 BMW Z3 158,545 miles
-3.0 L engine with the steptronic trans
-rare 3 piece ac schnitzer wheels
-ac schnitzer lowering springs
-trunk welds and rear diff mount are in perfect condition
-leather interior is all very nice-small tear in shift boot
-glove box doesn't sag
-brand new soft top installed
-power top/windows/mirrors/heated seats all work perfectly
-has none of the typical engine oil leaks, previous owner had the valve cover and oil filler gaskets changed
-will include extra BMW coolant, Foxwell scanner with BMW software and round pin adaptor to be able to reset oil lights and interact with all BMW modules
box of misc spare parts-brand new spark plug set, extra fan belts, extra fan blade, oem disa valve that can be rebuilt, extra window slider bushings, more in there just don't remember of the top of my head
-oem tool kit is still in the trunk
5/16/25 - 157,650 Brought
5/23/25-157,707 New window sliders/new air filter/new power steering reservoir seal
5/24/25-New front Bilstein struts and strut mounts/oil + filter change/new Bosch front brake pads
5/26/25-New Bilstein rear shocks and upper mounts/New trunk struts
5/30/25-157,707 New Bosch rear brakes pads/new glovebox latch
5/31/25-157,710 New purge valve
6/4/25-157,710 New, radiator/water pump/thermostat/upper+lower radiator hoses/new overflow
hose/new radiator mounts and clips/both fan belts replaced
6/13/25-157,835 New Disa valve
7/1/25-New Secondary air valve hose
7/26/25-157,985-Robbins soft top/tension straps and new rear seal installed
8/9/25-158,062-New rear sway bar links
8/29/25-158,151 New motor mounts installed
8/30/25-158,151-New control arm bushings and mounts installed
9/25/25-158,241-New flex disk installed, new trans mounts installed
10/3/25-158,241-AKG poly subframe bushings/Powerflex rear diff bushing installed
Only cons I can think of:
stock BMW CD changer in trunk sometimes works and sometimes gives an error message
AC works, but doesn't cool very well-I didn't get to this yet because I usually just drove with the top down
previous owner installed poly trailing arm bushings-they are in great shape but have the typical poly bushing squeak-can't hear them if the top is down
Status
