CNC Plasma Cutting
I have access to a CNC plasma table big enough for a 4X8 sheet up to a 1/4 inch thick, i am trying to start fabricating parts and would like some ideas to maybe break the burn table in
What skill level with fabrication do you have?
I could think of a few offhand; manifold flanges, carb adapters, block off plates, drivetrain adapters, etc.
Yeah x2 on the location. Also another good Idea might be to have some prefab differential armor or brackets for mounting things to the engine, like saginaw pumps, york compressors, or spare alternators.
Where you located
And things to make would have to be beadlock rings and tow mounts that bolt into the chassis rails and I got a few more ideas
Thanks everybody for the ideas I'm in the process of designing a "you weld it" bumper the bead lock rings i can do. I will look into the TBI adapter, I am still learning the cad software but mid January i plan to have the first bumper cut and put together. My location is RC, SD but i will get some bead lock rings put together and post some pics soon thanks for the ideas
By the way what size bead lock rings are you looking for and do you want me to supply bolts for the rings
