Clutches
Fallon,NV
Ok Gang my Clutch finally gave up the ghost after 2 years of hard use HEHE any recommendations as to what Clutch pack to buy or wether i should go with a center force or ? any help is as always greatly appreciated
Dan :cheers::steer::bounce::bounce2:
Dan, sorry I didn't respond earlier. I had a centerforce in my Jeep and I really couldn't tell a difference. I went with a stock style replacement in my 4runner, so I would probably just go with a stock style (i.e. Napa etc.) clutch from whomever you find the best deal.
I am not up to speed on the 420 conversion, but does it use a chevy clutch, toy clutch or a mix of the two?
Jack
If you're using the sb chevy, then get a flywheel drilled for 12" clutch. Run the clutch out of a 6.2 diesel. Mine had a hydraulic throwout bearing, but I think you can interchange the throwout bearing, don't know. You'd have to ask the parts guys. The 12" clutch, I got a RAM for towing from Summit. With a 6500 lb truck and a healthy 400 I couldn't get it to slip pulling a 30' cattle trailer fully loaded. On the other hand the 11" clutch in my 400 ford using Autozone stuff sucked. I finally threw the disc away and bought a top of the line Big-A HD disk the last time. It held up a little better but the difference in holding between a 12" and the 11" was night and day.
I've had decent luck with the Borg-Warners from Kragen???or Pep-Boys. Nothings going to hold up to slipping the crap out of it, but the more organic it is, the easier it is on the flywheel. A long-life semi-metallic type will get grabby when they get hot, and they wear the flywheel a lot more. The metal puck type are totally unsuitable for slippage. They are like and electric switch, on or off, no inbetween.
