Clutch "While you're in there" items
Mississippi Gulf Coast
I have an 87 FJ60 with an H55 5 speed that was installed in the 2002-2003 time frame at unknown mileage by a PO. The car currently has 165k miles. The throw out bearing or clutch fork appears to be shot. So the trans/transfer will be coming down and that will be getting replaced.
My question is, are folks just doing the entire clutch kit, rear main seal, etc. when you do this? Or if (big if) all that was done when the transmission was installed, do you just repair what needs to be repaired?
What is the common wisdom here?
Just my opinion on what I would do, change it all out. With that many years/miles on it, would be my luck something would leak or go out right after I replaced only part of it. Pain in azz if doing it yourself, but expensive too if paying someone to go back in to replace the rest later on.
Do the seals if its not bone dry in there. Reseal the trans/t case if not dry.
Same amount of work to pull the trans to do each of those jobs separately.
Or just slap a clutch in it. How big of a snowball do you want? Haha
