Clutch Problem Please Help.
Utah
I have only had my cruiser for about a month now and I decide to take it wheelin today. When I got in it I noticed my clutch was feeling funny and as I drove it got worse. When I came to a stop sign I pushed in the clutch and it just kept going, it would disengage. I dont have a lot of experience with clutches but it seems that it is loosing pressure. I can pump the clutch pedel and it works fine for about 5 mins and then I have the same problem. Let me know if you had any advice. Thanks
I also wanted to post a pic for you to look at of my little trip.
Slave cylinder. I can pretty much gaurantee you that it is on its last leg. Replace it, rather than rebuild it, and do the same for the master cylinder. Cover your bases and you'll be alright. Easy start to getting to know your cruiser. And welcome!
Sounds like a slave to me. I had the same thing on my pig. My wife happened to be driving it at the time:frown: I was able to pump the clutch to get it home and just swapped it out with a new one. It took a while for my wife to trust the pig again.
Could be either cylinder. Replace both so you only bleed once (why, there's a pun :) ) They're old - let them go without torturing them with extraordinary measures. Nothing lives forever.
Also, use thread lock on the slave cylinder shaft after you adjust. If not, I guarantee that it will back off and you will be cursing within a month.
slave ..slave ....slave...slave...slave....replace the slave and I hope it pisses 'ol Jesse off
