clutch master install help
Ogden UT
Website
www.myspace.com
hi guys, I know this is a no brainer but my junk just doesn't want this thing to work!! I just got a clutch master for my 77 40 from maf and I can't seat the double flare! the B nut seems to hit/bottom before the flare can seat. I can see wear all along the end of the b nut where it's hitting. has anyone else had this problem? I think I am gonna try to file the nut down some and see if that works. I don't think that should have to be done though, it should just go in no prob. maybe they sent me the wrong year or something? it is an aisen? and is painted blue if that helps, thanks!! I would post up a pic but my comp is not detecting my camera.:doh:
I would not file anything down, as this may only lead to needing to change out more parts...
If the b-nut will not seat the flare in the area that it is supposed to, your master cylinder has a machining error in that area, and you will need a different one.
Good luck!
-Steve
aren't those parts just rebuilt? in other words it fit on something else once before. maybe I should give maf a call monday to see what's up.
Would be a good place to start....Steve-o is a good guy...give him a hollar, and see what is going on....pics are worth a thousand words, and they will want some.
:beer:
Hak sherpa sherpa, Abak Allah!
oh wait...
America,
F U C K Y E A !!!
yeah, PO overtightened therefore flaring out the b nut causing it to hit near the bottom of the threads.
