I have a 1976 FJ55 with 2F, stock 4 speed and Tcase. I also have an Eaton Overdrive that is bolted in front of the Toyota 4 speed. I am getting my act together to do a clutch install. The overdrive has a blue knob that sits on the main stick shift lever. Popping this lever while clutching will drop the RPM's by about 500-600 RPM. It also works with all four gears and is great on the highway etc.
My question is this: is there anything to watch for when doing the clutch swap: flywheel, bell housing, gaskets etc??? I would like to know this ahead of time: not really sure what to expect when I drop all the running gear. I have replaced the clutch on my FJ40 so I am somewhat familiar with the procedure etc. Anyone replaced the clutch with an overdrive in place before???
Cheers,
Max
Cheers,
Max
