I am trying to troubleshoot some clutch hydraulics issues while my engine and transmission are out. I have a 1991 HDJ81 with a H151f. Boosted clutch master cylinder that Toyota doesn’t make anymore and a headache.
I had some dramas a while back where my clutch pedal went to the floor while driving. Basically no pressure in the hydraulics. Slave wasn’t moving. No apparent leaking or fluid loss. Took the truck to a shop for clutch replacement, and a new OEM slave cylinder. When the truck arrived at the shop magically the clutch pedal started working again (before all the new parts).
Fast forward to now. Engine is out due to a snapped crank at #1. I’m still worried the hydraulics aren’t sorted.
My question here is should my hydraulics still work without vacuum on the clutch booster? If I go out there right now it feels just like it did the day it went to the floor and the slave doesn’t move at all when pressing the clutch. I just don’t know if that’s because it’s not seeing a vacuum or because the booster or master is going out...
Cheers.
Cheers.
