- Joined
- Oct 9, 2006
- Threads
- 22
- Messages
- 67
So the clutch disc got moved in the garage and not to sound dumb but I can't remember which side goes up against the flywheel. Any help with that would be great. HJ-60
Best to change your pilot/spigot bearing in the flywheel as often they are missed and not changed resulting in another pull down.Thanks, kinda figured it might only go in one way but I didn't want to get the engine back from the machine shop and be messing with that. How thick is a new clutch? The FSM tells me the minimun rivet depth and its above that but not by much, I know optimally I would replace the whole assembly but as funds run low I am wondering how much time I can get out of the clutch I've got.
The picture above looks like a new or nearly new clutch disk to me. Use that as an example for how much material should be there. If the rivets are flush with the material surface then you're done. It's time for a replacement.
If you want to go cheap, look at the pressure plate (part laying down in the picture) and if it is not scored or badly blued buy only the clutch disk, pilot and throw out bearings and reuse the pressure plate.
I'm paying almost $600 (Canadian) for the whole kit, more with shipping to the U.S, way more than I was expecting. So after machining, and rebuild (3 yr/36,000 mile warranty) and the rebuild kit I was really just like F@#K that the most expensive clutch ever. Do you have a website or a phone number of a place that would ship to the States?
