Clunking Springs....
O.K., the new OME suspension has been on for a few months now and I've got this "clunking" sound that is getting more pronounced coming from the front springs when I turn the wheel to the left and right. It's done it since I installed the springs but, it is getting louder and occuring more frequently.
When I stand in front of the vehicle and have someone turn the wheel lock-to-lock, I can see the front spring packs shifting left and right. ARB in Seattle says the noise is definately not normal and shouldn't be occuring at all. They are calling it a bushing issue, but the bushings are new OME and torqued per their specs.
Anybody have any good ideas on this one?
Thanks,
-dogboy- '87 FJ60
It is not a bushing issue, and who at ARB told you this?
The leaf spring is moving in the pack, that is what is making the noise.
-Steve
First-retighten the u-bolts if you have not done that since intstallation. Second-pull out your old copies of Toyota Trails-someone asked this exact question about 1 year ago and I seem to recall that Mark Whatley said it was pretty common.
My 60 does it as well, a bit more sense I added an extra leaf. Make sure everything is torqued, if so and it still does it............its normal.
FWIW my fj40 and 45 with OME doesn't do it, just a 60/2 thing, prolly cause the springs are longer
My OMEs in my 62 make the samme damn noise. At first it was due to the U-bolts lossening up a little after initial installation and a run down to Moab. But after countless checking of their torque, it still does it, and you can see the leaves moving in the packs when cylcing the steering. I was thinking about new u-bolts to mmaybe give themm a second chance at clamping the springs down. But maybe not. ??? :D
