Clunk noise
Caribou, Maine
I am considering buying a 94' 80 w/ 160K. It has the factory lockers, and most things seem to work. I test drove it last week and it drove nice. The only thing I noticed was when I braked and the vehicle came to a stop I felt and heard clunk coming from the rear.
I backed up and broke again and felt the same clunk. It did not sound like U joints but I didn't drive it for that long.
By the way price is $8500 is that about right?
:grinpimp:
Mine has that same clunk, but on the front axle. I have found it to be a loose ring/pinion. I'm going to pull the diff and have it adjusted or just have the gears replaced. Keep in mind that on an old truck with lots of miles the metal can wear down on those gears and they don't fit as closely as they did from the factory. When you get it you should replace all fluids (Fr/Rr diff, Tcase/center diff, engine oil, trans fluid). Pay attention to the trans fluid, diffs, and transfer case for metal shavings in the oil or on the plug... alot of them usually indicates that something is out of whack and should be adjusted.
The best way to figure out if that is the issue is to jack up the truck off the ground (all wheels, and use jackstands!). Lock the front and rear diff (with the key in "ON" position). You should hear them engage (this is a good pre-purchase test too). Put it in Park and Low Range, release the handbrake. Get out of the truck and physically move the wheels with your hands. You will probably feel slack. Watch the u-joints... if the wheel is moving more than they are, your ring/pinion needs to be adjusted. You can always take the diff (removed from the pumpkin) into a shop and have this done.
Todd,
You did not note anything about the truck you are looking at in terms of miles or condition. So, it's either a ripoff or its a great deal and you're the only one who knows which. As to the clunk, 80s typically have a slight clunk due to all the drivetrain components and usually its just a driveshaft that needs a shot of grease.
DougM
Doug,
Overall the Cruiser is in good shape, the body is square no rust as far as I can tell. Some paint fade on left fender, right fender is a re-paint.
The interior is good as well, no 3rd row seat though:frown:.
Black ext, w/ tan leather.
Now, the decision to try to buy it now, or sell my Saturn L300 & then use the money to buy it.
Not a big problem. If you have sliding windows in the cargo area then your truck originally had 3rd row seats so all the bits are probably there and all you need is the seats and maybe the seat belts.
You can post a "Wanted" ad in the proper forum here on 'Mud. I have 2 sets in tan leather that I would like to sell but have been too lazy to post an ad. Lots of guys pull theirs and would be happy to sell you a set.
-B-
Thanks Wulf, it does have the sliders and the mounts in the back. If I purchase it I might hit you up for one of those seats!
