Clunk in Steering
Western, SD
I have recently noticed a new clunk when I turn. Fresh, tie rod ends, stabilizer and knuckle rebuilds. I had my wife turn the wheel while I was looking underneath the truck. There was a clunk that seemed to be originating from the steering box. It actually caused the coolant lines to pulse when it hit a certain point like the flow was shut off for a split second. Has anyone come across this or know what it could be?
I have recently noticed a new clunk when I turn. Fresh, tie rod ends, stabilizer and knuckle rebuilds. I had my wife turn the wheel while I was looking underneath the truck. There was a clunk that seemed to be originating from the steering box. It actually caused the coolant lines to pulse when it hit a certain point like the flow was shut off for a split second. Has anyone come across this or know what it could be?[/QUOTE
The lines might have done that if you hit the left or right limit stops. But try checking the u-joints on the steering shaft.
Good luck.
I had one from my OME steering stabilizer. Had to grind down the washer so it wouldn't rub against the drag link.
Did you ever figure this out? I think I have a similar issue. Any help would be greatly appreciated!
