clock replacement or upgrade options
Dear forum,
My clock is kaput. Are these still available or is there a more modern replacement, perhaps with a compass and inclinometer out of a later model?
Cheers,
Rich
That little wee digital clock there? Sorry but inclinometers, compass, altimeter, barometer, temperature gauge and all those cool things had there own and much larger pods that won't fit where the clock goes. I think an auber gauge would fit in there if you needed an extra gauge otherwise that's the same clock used in every 70 series model up until the new dash
Also the same as the ones I've seen in 80 series and 60 series. Finding one used should be too hard.
Not sure if there's a 12volt and 24volt version
Thanks for the reply 77cruiser77. Do you happen to have any pictures of factory versions of those various gauges and such if Toyota made any?
I tried to have mine repaired here in Liberia (the local electricians can be surprisingly resourceful) and all I got for my $5 was a glowing wire behind the glass. That was technically an improvement as there was nothing happening in the unit before but it still fell short of any actual utility :).
Best,
Rich
Dear forum,
Cheers,
Rich
Your current clock is more " modern "than the Aussie ones , we didn't get that alarm and stop button.
